| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Combination |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
How to add combinations to the Forces and Moment's output report in AutoPIPE?
Example: How to add combination: Gr+P to above report?
The results displayed in the Forces and Moments report come from the Non-code Combinations tab of the Load Combination dialog box. Only default combinations are initially displayed in the output report. In order to have additional combinations appear in this report they will first need to be added as a User defined Non-Code combination using the Load combinations dialog as shown below:
See AutoPIPE help for details on creating User defined combinations.
Before closing this dialog, confirm that the Print column is checked on for the combinations wanting to appear in the output report. Otherwise the combination will not be printed in the Forces and Moments or any other Non-code sub-reports.
