| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Combination |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
How to modify existing User defined combination names?
After the user combination is created, the names are hard coded into the program's database and cannot be changed using the User Non-Code or Code Combinations dialog.
Use one of the following options:
A. Modify the User Non-Code Combinations names under the column labeled "Combination" in the grid of the Load Combinations dialog. Only the User combinations names can be modified, the default names are grayed out.
OR
B. Delete an exiting combination and then re-create a new user combinations with the correct name and settings as needed
