| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Combinations |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
Can the default Combination Name be renamed - example: "Gravity" to "GW"?
We apologize for the inconvenience, however the default names are hard coded in to the program and cannot be changed. Only option is to create new user combinations that are saved to a combination file (*.CMB) and import them into new models as needed. See online help for "Import Combination File" details and instructions.
