| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | Analysis | ||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 |
Is it possible to export / store / import AutoPIPE Static Analysis settings (load-case)?
I am working with AutoPIPE Series 5 version 09.06.00.15.
Bentley apologizes for the inconvenience but at this time AutoPIPE V8i 09.06.xx.xx and lower does nto have the ability to import/export Static analysis settings between models.
Open a model that has the correct Static analysis settings, save the file as a different name to protect the original model, using File> Insert AutoPIPE Model (DAT) command to import the model in, and update the Pressure / Temp / PipeID information as needed.
This issue has been logged under TFS-E82441: Add feature to Import / Export Static analysis load sets between models.
