| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Analysis | ||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 |
I wish to run a thermal-only analysis load case in an Static Analysis Load Set. How do I disable the gravity case?
If the Static Analysis Load Set has just one load case to be analyzed, use a Linear Analysis. However, this will ignore Gaps, Friction, and Soil settings in the model.
A Non-Linear Analysis takes Gaps, Friction, and Soil settings into consideration, HOWEVER now there is a load sequence where GR (Gravity) is always the initial case to other load case and cannot be disabled.
