| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Note |
| Date Logged & Current Version | June 2019 12.01.00.10 |
The following appears when making modifications in AutoPIPE:
Note
N56-12: Temperature dependent material properties has been updated.
OK
why and how to avoid it?
This is just a message to let the user know that due to some setting changes in the program, temperature dependent material properties are going to be updated. Again, any data that is automatically calculated based on temperature will be updated. All other data will remain unchanged.
Note: when PipeID material is set to NS (Non-Standard), the program will always run a check on the material properties regardless of pipe properties setting modified (1040494).
