| Version(s): | All | ||
| Area: | Installation error | ||
When installing AutoPIPE the following is displayed:
AutoPIPE Preview Handler:
Error 1001. Exception has been thrown by the target of an invocation. --> Object release not set to an instance of an object.
What does this mean?
Who to avoid?
The new AutoPIPE V8i 09.06.xx.xx Wix installer is trying to install a new feature. This new feature has the ability to show a small thumbnail image of the model's screen view when last saved in a pane located ont he right side of the file name when using the File> Open command. Example shown bellow:
This new feature is only available when installing the program on Win Vista, Win 7 or higher operating system. This Preview Handler should not be launched when the application is being installed on Windows XP. This is wrong behavior.
Press the OK button on the dialog if the Preview Handler Error 1001 appears. The program will finish installing and function correctly with the only one exception of not displaying a thumbnail image as of the model. This will be updated in a future version of the program's installer.
