| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | License |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
How to set a default license edition (Standard, Advance, or Nuclear) when using AutoPIPE?
AutoPIPE always uses the last license edition that was active when the application was closed.
Example:
Step #1: Select Standard edition at the license screen (shown above), uncheck "Show Welcome Screen on startup", press OK, and close the application.
Step #2: Now restart the program, notice how the license screen does not appear, and that the application started using STANDARD license .
Again, the application will always use the last edition of license when closed. Based on the example above, providing the edition is not changed by the user, AutoPIPE will default to a STANDARD edition license when the application is started.
AutoPIPE Edition License issues
