| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version | May 2015 09.06.02.06 |
How to generate a report showing the maximum displacement
The Displacement output sub-report cannot sorted from highest to lowest value. However the reports can be filtered based on a defined threshold (i.e. Greater than this value, Less than this value, Between these values). Suggest reviewing the following AutoPIPE commands:
a. Results> Filter Criteria > "Displacement"
b. Results> Output Report> "Limit results to highlighted points" and "Apply Filter Criteria (Result/Filter)"
In addition, do not forget the power of the results grids, while viewing the results grids, select the Displacement tab and double click the column heading to order the column in increasing order, and then double clicking the same column heading will reorder the column in decreasing order. The grids can only be ordered one column at a time.
