E-01 "No Active AutoPIPE Advance or Nuclear license found. Please activate your license before runni
Product(s):AutoPIPE Nozzle
Version(s):ALL;
Area: licensing
Date Logged
& Current Version
June 2019
08.11.08.35
Problem:
The following appears when starting AutoPIPE nozzle and selecting Full license:
Why and how to avoid it ?
One would need to make sure that their licenses inside of BLT (Bentley Licensing Tool) and/or LMT (License Management Tool) has a valid license for AutoPIPE Advance and/or AutoPIPE Nuclear Status = OK or Activated.
Note: if more than one version of AutoPIPE is installed, AutoPIPE Nozzle would have been installed and licensed with the highest version of the program.
Example:
If AutoPIPE 09.06.02.06 and AutoPIPE 12.01.00.10 were both installed on the same computer side by side. AutoPIPE Nozzle would have been originally installed with AutoPIPE 09.06.x.x However, AutoPIPE Nozzle software would then have been overwritten when installing AutoPIPE 12.x. Therefore, AutoPIPE Nozzle would work on a valid license for  AutoPIPE 12.x.
As mentioned, 09.06.x uses LMT while AutoPIPE 12.x uses BLT. Therefore if user signed into current session of CONNECTION Client, would need to have AutoPIPE Advance or AutoPIPE Nuclear entitlement correctly configured. Otherwise, AutoPIPE Nozzle would not be licensed.  .
Warnings, Errors, Crashed, Confirm Messages
