| Version(s): | ALL | ||
| Area: | Analysis | ||
On the Load tab, Operating Pressure field is limited to 3000 psi. Why?
In AutoPIPE V8i 09.05.xx.xx and lower, there is an internal limitation of 3000 psi for data entry. A new enhancement (CAE-CR-11051) has been logged to increase this limitation.
