| Version(s): | ALL | ||
| Area: | Analysis | ||
Using Tools> Flange Analysis. Look-up dimensions for a 30" 150# B16.47 WN don't seem to be correct. AutoPIPE says it is 38.75" OD with 28 bolts, 1.25" Dia on a 36" bolt circle. B16.47 says it is 34.94" OD with 44 bolts, 0.75" Dia on a 33.31" bolt circle.
These values are referring to ASME B16.47 - 1996. AutoPIPE use a different code year.
Use one of the following methods see the code years used by the program.
A. Please see the following AutoPIPE help section:
Help > Contents> Search Tab> enter "Flange Analysis Dimension Library" (include the quotes), press List Topics button, double click on the selected topic from the list provided to see more information.
B. Select the help button from the Flange analysis dialog and navigate to this page using the hyperlinks.
