| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Analyze |
| Date Logged & Current Version | April 2019 12.00.00.14 |
Why are B16.5 or B14.7 selection options not shown on theĀ Flange / bolt Dimensions dropdown listing?
- Open AutoPIPE,
- Open the flange analysis dialog
- Select the Flange tab
- Put your cursor in the field for Flange / bolt dim and press the keyboard F1 key.
- When the help appears, scroll down the table and press the hyperlink for "Flange/Bolt Dimensions".
- See the help information on filed that appear. The listing depends on the component library selection in General model options.
