| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Analysis |
| Date Logged & Current Version | June 2019 12.01.00.10 |
In Time History analysis, can force only be applied to the end point nodes or can they be applied at segment mid points?
Time history loads can only be applied through supports. Supports can be located at the start, end, or midpoint of a pipe segment.
Dynamic "Time History" Analysis
