Glossary of Terms
Term / Field Name
Definition / meaning
Related Features
Accrued Cost
The cost of goods or services received or incurred during a period, or when the lack of supplier billing forces the buyer to accrue a related cost. A lack of supplier billing typically occurs when an invoice is in transit, and does not arrive from the supplier until after records close for a reporting period
Timesheets/timecards and Usage
Subcontractor dockets
Daily cost and production
Activity
An Activity represents any planned work item, including Programme/Schedule activities, Costs Codes/Accounts, Diary questions, and Reporting codes or anything else.
Activities hold planned and actual dates, cost, labour, and quantity budgets and can be used to track physical progress and the usage of resources (People, Equipment and Other)
Progress measurement
Program / schedule collaboration - Activity Management
Actual Cost (AC)
Actual Cost is the total cost incurred for work completed to date.
"Cost" does not necessarily refer only to financial cost and labour hours; other units can also represent cost
Analytics
A general term relating to metrics and measures that provide insight into project performance
Earned value / performance management
Application Programming Interface (API)
SYNCHRO Perform uses REST APIs (also known as RESTful API) as the application programming interface
General
Assignment End
End date of the attendance entry
Attendance and competency
Assignment Start
Start date of the attendance entry
At Complete Budget
The budget value at the completion of a project
Attendance
Physical attendance of people at a location and time
Attendance Area
A location where attendances can be recorded
Attendance Reference
An identifier of the Person used for attendance recording (e.g., a card number or badge number or QR Code)
Battery (V)
Battery voltage from the equipment item telematic device
Plant and equipment tracking
Break Duration
How long the Resource was on break for. Enter in decimals. For example, 30 minutes is shown as "0.5", not "0.3" or "30"
Client
The client of the SYNCHRO Perform user company (typically the owner of the asset being constructed)
Resource Management
Company
Name of Company for the resource as defined in the Resource Assignment
Resource Management - Companies
Competency
Competencies hold relevant attributes for a Person, which may include qualifications, licences or keys issued, and the status or validity of these qualifications (such as license dates and site access
Cost Performance Index (CPI)
A measure of a project's cost efficiency, this is the ratio of Earned Value to Actual Costs
Cost Rate
How much a Person or piece of Equipment costs your business per hour
Cost Type
A definition for a given cost, typically Labour, Material, Subcontract etc.
Cost Value
How much it costs a team to use the Resource
Creator
User that created the record
General
Critical Path
The shortest time a project can be completed in
Current (Estimate at Complete) Budget
The budget typically estimated needed to complete a project, also known as the "working budget"
Date
The date of the entry
General
Dayworks Value
How much a team can charge a client for using the Resource on a Dayworks basis (usually for out-of-scope work)
Demobilized
Yes - Identifies that the resource has been demobilized from the project as defined in the Resource Assignment
No - Identifies that the resource has not been demobilized from the project as defined in the Resource Assignment
Resource Management
Diary Log
The Diary Log shows all Diary entries made.
They can be filtered by date, Users, and other attributes, and add comments and files.
Site Records
Diary, Daily Dairy
Users can track a project’s day-to-day on-site developments via Diary entries
Site Records
Direct
Labour completing productive work, such as welding
Resource Management
Discipline
The discipline of the product work
General
Docket (Ticket)
Dockets group Resource Usages (Timesheet entries) with a Company supplying services.
One or more Resource Usage(s) can be grouped to a single Docket. Typically, this is on a per-day basis, but can span longer timeframes.
Dockets can also be associated with Invoices and Purchase Orders to assist in the reconciliation of services provided.
Invoices can be locked, with the ‘locked’ status cascading to lock Dockets and Resource Usages linked to the Invoice as well
Docket ID
The unique reference number of the Docket
Duration
The duration of the attendance (End Date/Time – Start Date / Time)
Early Curve
A version of the plan that assumes early completion
Earned Value (EV)
Also called "Budgeted Cost of Work Performed", Earned Value is the value of the work completed to date, and is recorded using the Progress functions, such as Quantity Progress or Tagged Items.
It can also be represented as: Earned Value = % Complete x Budget at Compete
Earned Value Method (EVM)
The Earned Value Method calculates the completion percentage for an Activity
Employment Agreement
The agreement between the Person and the company
Resource Management - Employment Areas
Employment Area
The area where the Person works
Employment Company
The company employing the Person
Employment End Date
The end date of the Person’s contract with the Employment Company
Employment Start Date
The start date of the Person’s contract with the Employment Company
End Area
End area of the attendance entry. Refer Attendance Area
End Comment
End comment of the attendance entry
End Date
End date of the attendance entry or Resource Assignment
End Location Latitude
End location latitude of the attendance entry
End Location Longitude
End location longitude of the attendance entry
End Time
End time of the attendance entry
Equipment
Any Plant, tools, or piece of machinery with a type, supervisor, rates, and a parent company
Resource Management
Event
Events are unplanned circumstances, such as equipment failure, bad weather, additional work requests and more.
An Event must be linked to an Activity and can only link to one Activity. For example, if a project involves laying a concrete foundation, it may be delayed if the cement mixer does not arrive. In this case, if the Activity is called 'Concrete Foundation', an Event called 'Project Delayed - Concrete Not Delivered' could be linked to it, with details of the delay in the Event.
Events and notices
Event Map
Events can be viewed on a map to give a clear overview of where they have occurred to reveal any patterns that develop
Events and notices
Event Report
Reports summarising Events can be exported as a PDF for easy viewing and distribution.
Events and notices
Extension of Time
Additional time allocated to a contractor due to unplanned circumstances that alleviate Liquidated Damages
Events and notices
External Reference
An optional unique identifier of the resource, typically from another external system (e.g., payroll number)
Resource Management
Finish Time
The time the Resource finished working. Captured in 24-hour time
First Receiver
The person who first took ownership of a material delivered to a company or site
Float
The number of days of leeway between completing one Activity and starting another
Gallery, Map
The Gallery displays all images captured on a project in SYNCHRO Perform, as well as their GPS location (where applicable), providing insight into on-site progress, and an overview of where work has been undertaken.
Photo management
Events and notices
Heading (deg)
Direction (in degrees) from the equipment item telematic device
Indigenous
The indigenous ethnicity of the Person
Resource Management
Indirect
Labour supporting production, such as store supervision
Resource Management
Inspection Reference
Universally Unique Identifier for the Inspection record
Resource Management
Late Curve
A version of the plan that assumes late completion
Liquidated Damages
The costs incurred by the contractor should a project not be completed on time
Resource Management
Location
The physical location of the productive work
Mobilized
Yes - Identifies that the resource has mobilized on the project as defined in the Resource Assignment
No - Identifies that the resource has not mobilized on the project as defined in the Resource Assignment
Resource Management
Nick Name
Nick name of the resource
Resource Management
Notices
Notices link to an Event and generate standard documentation, such as letters, forms, and other correspondence.
Notices are defined through a template
Events and notices
Notifiable User
These are people linked to an Activity or Event who receive email notifications when changes or comments are added.
As you can see below, Owners and Notifiable Users are separate lists, however the Owner is added to the Notifiable Users list by default.
Those with the appropriate level of permission can add more people to both the Owners and Notifiable Users lists, and remove them
General
Original Budget
The budget typically submitted to a client before a project is awarded, this is unlikely to change
OEM
Original Equipment Manufacturer
Resource Management - Equipment
Other Resource
Any other generic resource types, including materials and general assets
Resource Management
Owner
Activities and Events all have Owners, who are generally expected to maintain the records and assign associated roles related to these jobs
Events and notices
People
Any person with a work role, supervisor, rates, and a parent company. Some People will also be classed as Users, which means they have an account on the SYNCHRO Perform website and/or mobile app.
Refers to anyone involved in a project in SYNCHRO Perform; they may appear in a Timesheet to record the work they've done as part of an Activity or Event.
Resource Management
Person Family Name
Family name of the resource
Resource Management
Person Given Name(s)
Given names of the resource
Resource Management
Person ID
Universally Unique Identifier for the resource
Resource Management
Person Name
Person name in display format based on project setting
Resource Management
Person Supervisor Code
Supervisor code for the Resource (if they are flagged as a Supervisor)
Resource Management
Planned Curve
A version of the plan that is most likely to occur
Planned Value (PV)
Also called "Budgeted Cost of Work Scheduled", Planned Value is the value of the work to be completed in a given timeframe.
It can also be represented as: Planned Value = Planned % Complete x Budget at Complete
Program
Also known as the "Schedule", this is the amount of work needed to complete a project.
A collection of Activities that defines the project, it includes dates, budgets, and a work breakdown structure
Progress
Progress is the incremental measurement of the completion of Activities
Project
SYNCHRO Perform project name
General
Project Total Time
Total usage inclusive of leave for the project
Project Working Time
Total usage exclusive of leave for the project
Purchase Order
The ID number on the record of any order. This is usually used when Dockets are not available, such as if the entry relates to Equipment or Other resources, rather than the work of a subcontractor.
QR Code
QR (quick response) Code data is a type of matrix barcode. Each Person resource has a QR code automatically generated.
Resource Management
Quantity
The amount of the resource used; this is also related to the Unit of Measure used.
For example, if the UoM is "hours", you would enter the number of hours worked. If the UoM is "loads", you do not enter the number of hours worked, but instead the amount of material moved, etc.
Quantity Progress
Earned value method to measure actual quantity installed
Rate Code
The monetary value of the Usage. The standard is "Normal", but others can be configured Rate Codes are used to provide more information about, and to give context for, a given Rate.
For example, a small crane may be leased from a company at a cost of $150 per hour. However, the company may also lease the crane with an operator at a cost of $200 per hour. In this case, Rate Codes (such as the term 'Dry Hire' for a machine without the operator, and 'Wet Hire' for a machine with the operator) explain why the Rate may be different for the same crane in different circumstances.
Rate Codes can also apply to any hours worked overtime or on public holidays. For example, if a person works a normal eight-hour shift, their Rate Code may be 'Normal'. If a person works a shift outside of normal business hours, their Rate Code may be 'Normal × 1.5', and if they work on a public holiday, their Rate Code may be 'Normal × 2'.
In this way, though the same amount of time is worked in each case, the Rate Codes show why the Rates may differ.
Rates
Rates are the amount of money People, Equipment, and Other Resources are worth for a set amount of Usage.
This is expressed as '$/Unit of Measure'. For example, if a small crane costs $150 per hour to operate, its Rate is $150/hour. Rates fall into three categories: Cost Value, Sell Value and Dayworks Value
Resource
Resources are anything involved in work on site.
There are three resource types: People, Equipment, and Other. ("Other" refers to any miscellaneous items that do not fit into the previous two categories.)
Resources are used to capture Resource Usages (time, loads, etc.).
Resource Management
Resource Assignment
Resource Assignments cover time-based assignments of a resource when they perform a role on a project on behalf of a company
Resource Management
Resource Identifier
An optional unique identifier of the resource, typically from another system (e.g., employee number, equipment number, etc).
Resource Management
Resource Note
Any relevant information related to the Resource itself
Resource Management
Revised Budget
The budget typically agreed to with the client, this can change according to the client's request
Roster End
End Date of the roster
Rosters
Roster End Code
End Code from the Work Roster, based on configuration in project settings. Refer Work Codes
Rosters
Roster Start
Start Date of the roster
Rosters
Roster Start Code
Start Code from the Work Roster, based on configuration in project settings. Refer Work Codes
Rosters
Rules of Credit (RoC)
Rules of Credit is a method of progress measurement for Scope Items.
Internally, Activities are used to represent the progress for each Work-Subprocess applicable to a Scope Item.
For these Activities, an earned-value method of 'quantity-progress' is used to allow progressive measurement of progress within pre-defined, percent weighted Work Steps (rules of credit gates)
Schedule Performance Index (SPI)
A measure of a project's efficiency, this is the ratio of Earned Value to Planned Value. SYNCHRO Perform can calculate an SPI using the budget for labour, quantity, or Value
Scope Item
A Scope Item is the identifiable scope to be completed. Example of Scope Items are piping spools or concrete foundations.
Scope Items can be related to one or more Work Subprocesses and there can be multiple Scope Items within a Work Package
Sell Value
Speed (km/h)
Speed (in kilometres/hour) from the equipment item telematic device
Standard Machine Unit (SMU) Hours
How many units of a given product (concrete, steel, footage, etc.) can be produced by a standard machine in a standard hour
Start Area
Start area of the attendance entry. . Refer Attendance Area
Start Comment
Start comment of the attendance entry
Start Date
Start date of the attendance entry or Resource Assignment
Resource Management
Start Location Latitude
Start location latitude of the attendance entry
Start Location Longitude
Start location longitude of the attendance entry
Start Time
The time the Resource started working. Captured in 24-hour time
Start time of the attendance entry
Subcontractor
An organisation providing services to the head or prime contractor one or more packages of work.
Resource Management
Supervision Roster
The Supervision Roster assigns Supervisors to People and Equipment, assisting in the allocation of time-keeping responsibilities, and in filtering to specific Supervisors for People and Equipment.
Resource Management
Rosters
Supervisor
Supervisor or Foreman that is authorised to assign work and record time on behalf of their team
Resource Management
Supervisor Family Name
Family name of the supervisor
Resource Management
Supervisor/ Foreman Code
Code used to identify the Resource’s supervisor
Resource Management
Supervisor Given Name(s)
Given names of the supervisor
Resource Management
Tagged Item
Tagged Items are used to track the physical completion of work using a series of progress gates. Progress is tracked by recording the date by which work on a Tagged Item is completed, passing a milestone gate.
Tagged Items represent unique physical items (such as piles, pumps, valves, etc.). Though Tagged Items are associated with a Register, they can appear on multiple Registers, such as a Procurement Register and an Install Register. Every Tagged Item on a Register is associated with an Activity.
Tagged Item Register
Tagged Item Registers are containers for Tagged Items
Tags
Tags are labels that can be used to group system entities
General
Telematic Last Seen (hours)
Time when equipment telematics device was last seen (recorded)
Resource management – Equipment
Telematic Last Seen At
Date when equipment telematics device was last seen (recorded)
Telematic Latitude
Last latitude of the equipment telematics device represented as a decimal angle 
Telematic Longitude
Last longitude of the equipment telematics device represented as a decimal angle 
Telematic Stationary (hours)
Number of hours the equipment has been stationary (i.e., equipment has not moved more than 100 metres)
Telematics
Equipment geolocation that provides a clear overview of where each equipment item is located at the current time
Telematics Identifiers
Telematics device identifier
Templated Report
A Templated Report is any report based on a template.
The template pulls content and data from SYNCHRO Perform into either a daily or weekly report, and can include photos, tables, charts, and user-defined content.
The templates are built using HTML, CSS and JAVASCRIPT
Daily diaries and reports
Time Zone
Time zone location of the attendance entry
Timeline
The timeline is a longitudinal record of changes on a project.
The charges are recorded as timeline entries attributed to users and related to system entity. For example: Comment against an Activity, creation of an Event, generation of a report, etc
Site -Timeline
To Complete Budget
Budget that remains from a given date to the completion of a project
Total Cost
The total cost for the Resource for the amount of time it worked. This data is entered automatically
Universal Unique Identifier (UUID)
A UUID (Universal Unique Identifier) is a 128-bit value used to uniquely identify an entity (or record)
General
UoM (Unit of Measure)
The metric by which the Resource is measured, such as "hours" for People, or "Loads" for digging equipment
Resource Management
Updater
User that last updated the record
General
Usage (Resource Usage)
Resource Usage records the use of a resource to complete work.
Different units of measure (kilometres, miles, kilograms, pounds, chainage,  etc.) can be used for different usages, and when combined with rates, this can be used to calculate costs
Usage Code
The conditions for a Resource, such as a shift type, time of day worked, etc. The standard is "Normal", but other codes can be added via the Settings menu
Usage Note
Any relevant information related to the Usage of the Resource
Usage Matrix (Matrix)
The Resource Usage Matrix is one of several methods to record the usage of People, Equipment, or Other Resource types on both Activities and Events on a day-by-day basis in SYNCHRO Perform.
Timesheets/timecards and Usage - Usage Matrix
User
Anyone who is given a SYNCHRO Perform account to enter their own data and information directly to SYNCHRO Perform or view data entered by others. Service accounts are also used for API integrations
General
Username
Username of the Person if they have a user account
General
Variations
Unplanned circumstances that can affect the scope of a project
Events and notices
Work Code
Work Codes applied to the Work Roster can define start and end times, days off, or FIFO days and automatically generate timesheet entries
Work Process
A Work Process is a grouping of one or more Work Subprocesses
A Work Process can represent a Discipline or Subdiscipline such as Piping Install or Concrete Foundations
Work Reference
The Activity or Event related to the entry
Work Role
Work Role for the person resource
Resource Management
Work Role Category
Category for Work Role Category
Resource Management
Work Role Category Type
Type of the Work Role Category
Resource Management
Work Roster
The Work Roster is used to set the planned working and non-working time for People on a project.
Work Codes can be added via the Settings menu
Rosters
Work Step
Work Steps are held within a Work Subprocess and hold a percentage weighting
The total percentage of all Work Steps within a Work Subprocess must equal 100%. Examples of Work Steps are “Stage”, “Install”, “Weld”
Progress measurement,
Work Subprocess
A Work Subprocess is defined by its Work Steps and their percentage weighting. Multiple Work Subprocesses can be associated to one Work Process. Examples of Work Subprocess are Above-Ground Piping Install and Under-Ground Piping Install, which would be associated with the Work Process of Piping Install
