SYNCHRO Perform / Bentley IMS Transition
SYNCHRO Perform is being integrated into the rest of the Bentley product suite for a variety of reasons including access to other products, new features, security as well as the SYNCHRO Suite. To get access to this, users will need to create and register a separate Bentley IMS account which will enable Single Sign On (SSO) access to SYNCHRO Field, Control, Cost and 4D if the subscription allows it. In this guide, you will create a Bentley IMS Account in addition to your existing SYNCHRO Perform Account. Once the Bentley IMS Account is setup this will need to be linked with your existing SYNCHRO Perform account.
Note: This guide is intended for end users when an Administrator has directed them to link IMS. It is important to note that your SYNCHRO Perform Account is not the same as your Bentley IMS Account. Over the coming weeks, this will be MANDATORY for all users and if you do not action your account will be LOCKED OUT. This deactivation will prevent you from accessing SYNCHRO Perform, but it may also occur due to the fact that you have not logged in within the 45 day period to maintain account validity. Please contact your project Admin if you have any questions regarding re-activation.
Bentley IMS and Linking it with SYNCHRO Perform
The benefits of IMS login include:
A single password to manage all Bentley products including enhanced security
Federation for organizations
Simplified experience when working across Bentley products
Step 1 - Set up a Bentley IMS Account (skip this if you already have one)
Go to: https://ims.bentley.com/ click on 'Register Now'. (If this link/URL doesn't work, please copy and paste the URL directly into your browser)
Click the blue “Register now” link underneath the Next button. Do not fill out the email field or click Next.
Users will have essentially 2 accounts (SYNCHRO Perform and a separate Bentley IMS Account), however once linked it will be the new Bentley IMS account only.
Step 2 - Go to your SYNCHRO Perform User Profile
Go to your SYNCHRO Perform Project URL. This will be similar to https://companyname.e7.site
In the top right corner, select the drop down beside your avatar and click on My Profile
Step 3 - Link to your Bentley IMS account
Under Change Details click on the blue Link Your Bentley Systems Account button
You will be redirected to a page to confirm your name and email
That's it!
Next time you go to your project and login, you will now select the green Sign in with Bentley Systems button which will prompt you to login with IMS.
