User Permission Role Matrix (Web access only)
Note: Feb 2024: This matrix is currently being updated to reflect recent changes.  The version published below may not be totally accurate
User roles determine the access capabilities for users and are the same across all projects the user can access. This matrix details all permissions for each user role in SYNCHRO Perform Web.
