| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT | ||
| Area: | Readme | ||
| Date Logged & Current Version | April 2016 10.01.00.09 |
| Version | Compatible with Bentley AutoPIPE CONNECT Update 1 (Version 10.01.00.09) ONLY |
| Build Type | Select Release Product |
| Operating system | English |
| Language | English |
| Date | April 29, 2016 |
The Bentley AutoPIPE Acceptance Test Set (ATS) provides the user with a recommended procedure for validating the integrity of the installed AutoPIPE 10.01.00.09 program.
Prior to any commercial or Quality Assured release, the accuracy of the AutoPIPE program is verified by the execution of Alpha Tests. These Alpha Tests consist of a matrix of test systems designed to capture key feature attributes related to numeric and functional processing. Each set of test outputs is compared to a prepared set of expected results (i.e. hand calculations, some other well-established computer program, etc.), and evaluated for acceptance. The test matrix has been developed, verified, and documented per the requirements of the Bentley Software Quality Assurance Procedures (D/N# QAP).
The Acceptance Test Set includes input files and full documentation covering a sampling of test systems and results documented from the Alpha Tests.
Although many program features are verified by the ATS, it should not be construed as being complete for testing of all program functions. Additional tests for specific program features are continually being developed.
You must have a CD drive or Internet access for product installation. The following prerequisites are required to run the Acceptance Test Set for Bentley AutoPIPE CONNECT.
| AutoPIPE | A fully authorized copy of AutoPIPE Version 10.01.00.09 must be installed on your system prior to installing the ATS system files. |
| Processor | Intel Pentium IV or higher. |
| Operating System |
Windows 7 Professional or higher Windows 8 Professional or higher Windows 8.1 Professional or higher Windows 10 Professional or higher |
| Memory | Minimum 2GB |
| Hard Disk | The uncompressed input files (.DAT, .CMB, .UNT, .SPC, .XML, and .OUT etc.) require at least 90 MB of hard disk space. |
| Input Device | Any industry-standard input device supported by Microsoft Windows. |
| Output device | Any industry-standard output device supported by Microsoft Windows. |
| PDF Reader | Adobe® Acrobat Reader 7.0 or greater |
When you receive an ATS DVD from Bentley, the product directory structure for this product appears as shown below. To install from the DVD, locate and run the setup.exe file. Refer to the Installation Help below.
|_autopipetestset
|_10010007en
|_product
|_install
|_setup.exe - This initiates the installation process. Follow the instructions given below.
Before you install the Acceptance Test Set files, you should confirm that you have adequate hardware and software capabilities to execute the test samples.
1. From ATS DVD, locate and run the setup.exe to initiate the installation process.The setup program will guide you step-by-step to install the contents to the hard disk.
2. The default destination directory is "C:\Bentley\AutoPIPE CONNECT\ATS".
3. The input files will be placed in the specified destination and the previously verified output files(benchmark) will be placed in a directory named “OUT” located in the destination directory.
4. Once all the files have been installed, the setup program will display the final dialog. An icon will be added to the program group allowing you to review this file at a later time.
5. Select “Finish” to complete the installation.
Licensing: There are no authorization or License File requirements to use the AutoPIPE Acceptance Test Set.
Full documentation, provided in pdf format is installed with the test files. You can also download the documentation from the documentation button.
Adobe Acrobat Reader
Documentation is provided in PDF files and can be browsed, searched, or printed with the Adobe Acrobat Reader. Information regarding the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
The user document numbers which correspond to this release are:
DAA037360-1/0001 - "AutoPIPE_Tutorial.pdf"
The "Acceptance Test Set" document number which corresponds to this release is:
QA25API-10.1.0
Error reports are available with client participation in the "QA & Reporting" services. Monthly error reports, periodic compilations of all open errors for respective software products, and details of errors fixed through individual software releases are posted to a private QA&R Community under the Bentley Communities website at:
http://communities.bentley.com/
Question 1: How do I get access to the QA&R error reports?
Answer: QA&R error reports are available on a private QA&R Community under the Bentley Communities website: http://communities.bentley.com/. QA&R subscription is required to access the QA&R error reports.
Question 2: My organization has QA&R subscription. Why I cannot access the QA&R error reports?
Answer: Access to QA&R error reports is available to the person(s) nominated to receive monthly error report notifications, by respective organizations, as listed on form 6-1-2: Contact Personnel for "QA & Reporting" Subscriptions.
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2015, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "AutoPIPE V8i SELECTseries5" folder of the product installation. By default, this location is "C:\Bentley\AutoPIPE V8i SELECTseries5".
Corporate HeadquartersBentley Systems, Incorporated |
International HeadquartersBentley Systems Europe B.V. |
Asia HeadquartersBentley Engineering Software Systems |
AutoPIPE ATS Install, License, and Run instructions
AutoPIPE Automatic Test Set (ATS) Release Notes
