| Product(s): | AutoPIPE Nozzle, | ||
| Version(s): | V8i | ||
| Area: | Modeling | ||
Does AutoPIPE Nozzle have metric and English units? how to change?
Yes, AutoPIPE Nozzle has 5 different unit libraries: select the System Tab, Units system from the drop-down list. Library units are: English (default) , Kip_in, metric, mmetric and SI
Customized units file can be created by copying / rename an existing units file e.g. English.UNN then editing using an ASCII editor.
