| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Code | ||
| Date Logged & Current Version | Aug. 2015 08.11.08.23 |
As the year changes, so does the existing materials change in AutoPIPE Nozzle, why?
Correct, as some code year may or may not have a specific material available, therefore the program selects a valid material from the Library.
Suggest that the System tab be completed first before entering data on the other tabs.
