| Version(s): | V8i | ||
| Area: | Localization | ||
Product Name |
AutoPIPE V8i SS4 09.05.01.05, |
Version Number |
09.05.01.05 |
Application Group |
SELECT Released Products |
Language |
Russian |
Solution |
Pipe Stress Analysis |
Operating Systems |
Windows XP |
Dependencies: |
Structural Dashboard V8i - English 08.11.09.08 or higher Bentley IEG License Service - English 02.00.20.01 or higher
This is maintenance release 1 to 09.05.00.21 and Nuclear QA&R version and fixes some nuclear ASME and JSME critical and Pipelink issues.
Bentley AutoPIPE V8i is a stand-alone, engineering application used for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 34 piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, Russian API, NEMA, ANSI, ASCE, AISC, UBC, and WRC guidelines and design limits to provide a comprehensive analysis of the entire system.
The Bentley IEG License Service MUST be installed to run this AutoPIPE version.
More information about this request is available by clicking on the following link: README
