Employment Agreements and Employment Areas
An Employment Agreement is an attribute that is added to the employment section of a Person record. Employment Agreement information can be used by a company’s payroll to support wage criteria.
Employment Agreements - Add/Edit/Delete
  1. Click on Settings > Administration > Employment Agreements.
  2. To create an Employment Agreement, click on Add Employment Agreement.
  3. Enter the Employment Agreement Name.
  4. Click Create Employment Agreement.
  5. To edit an Employment Agreement, click  , make the required change and click Update Employment Agreement.
  6. To delete an Employment Agreement, click  .
    If an Employment Agreement has a grey icon  , there is existing associated data with a Person Resource and cannot be deleted.
 Employment Areas - Add/Edit/Delete
An Employment Area is an attribute that is added to the employment section of a Person record. Employment Area information can be used by a company’s payroll to support wage criteria.
  1. Click on Settings > Administration > Employment Area.
  2. To create an Employment Agreement, click on Add Employment Area.
  4. Click Create Employment Area.
  5. To edit an Employment Area, click  , make the required change and click Update Employment Area.
  6. To delete an Employment Area, click  .
    If an Employment Area has a grey icon  , there is existing associated data with a Person Resource and cannot be deleted.
