Recommended Hardware and Software
Bentley recommends these specifications for the best SYNCHRO Perform and SYNCHRO Perform Mobile experience. Bentley only provides support for devices manufactured less than three years prior to the current day, and does not support devices without the processing power to run the SYNCHRO Perform Mobile app. Please see the table below for the minimum specifications and recommended versions for the Android, iOS and Windows platforms:
  Android iOS Windows Tablets
Earliest Version/Operating System Supported 7.1.1 (API Level 25) 16.1 Windows 7
Architecture/Platform/Recommended Version Latest Version Latest Version Windows 10 and 11
RAM 3GB n/a 8GB
Release Date 2020 onwards 2020 onwards 2020 onwards
*  The iOS on an Apple device must be no more than one iteration behind the most current iOS available.
