Project Settings
Each project can be configured independently using the settings. The settings control the behaviour of the project including some reference data. Settings can be edited at any time.
Setting Area
Use
Possible values
Mandatory
General Settings
System Admin
Name
The name of the project
Status Type
Used for grouping projects according to status
· Active (default)
· Training
· Archive
Default cost unit of measure
Sets the UoM for Activity Revised Budget Values which are consistent across all Activities and are displayed on reports
Based on UoM configuration
Protected classification
To enable the Australian Government's Protective Security Policy Framework's 'Protected' classification for a project.
External reference
Unique identifier
Location
Short name or address describing the location of project
Location Latitude
Latitude represented as a decimal angle
(e.g., -27.463881) [-90 < latitude < 90]
Location Longitude
Longitude represented as a decimal angle
(e.g., 153.012451) [-180 < longitude < 180]
Project support contact
Project support contact details - shown in Help menu
Name, telephone number, email
Date format
Format of how dates are shown in the project
dd/mm/yyyy or mm/dd/yyyy
Tags
Tags created here act as placeholder tags and may be applied to other entities
Author copyable comment/attachment tags
Tags created here, and when present on a person, will be automatically applied to new comments and attachments that person creates
Person display name format
The default name format for people names across all pages within SYNCHRO Perform (case sensitive)
· Given Family (default)
· FAMILY, Given
· FAMILY, GIVEN
· FAMILY Given
· Family Given
· Attendance Ref (5 chars), FAMILY, GIVEN [Supervisor Code]
Classification period for Events
Number of hours in which a new Event must be classified
Editable discussion period for Comments
Number of hours for which Comments are editable
Record time of status change on work
Automatically record times for status changes on Activities and Events
Tagged Item actual quantity resolution order
The first populated quantity will be used as the Actual Quantity at complete for Tagged Item Activities
· Actual Quantity at Complete (default)
· Actual Quantity at Complete > Revised Budget Quantity
· Actual Quantity at Complete > Current Budget Quantity
· Actual Quantity at Complete > Revised Budget Quantity > Current Budget Quantity
· Actual Quantity at Complete > Current Budget Quantity > Revised Budget Quantity
Default Usage Codes
For People
The default Usage Code that is applied to People Resource Usages (Usage Code is mandatory for all Usages)
Defaults to “Normal (N)”
For Equipment
The default Usage Code that is applied to Equipment Resource Usages (Usage Code is mandatory for all Usages)
For Other
The default Usage Code that is applied to Other Resource Usages (Usage Code is mandatory for all Usages)
Timesheet / Resource Usage configuration
Default timesheet entry day
· Today (default)
· Yesterday
Allow negative Resource Usage values
Allow resource usages to be entered with negative amounts
Allow self-approval of Resource Usages
Only affects Users below System Admin that are permitted to approve entries. Does not affect Client Resource Usage approvals. Only System Admins can change
Allow rejection of approved Resource Usages
Only affects Users below Project Config that are permitted to reject entries. Does not affect Client Resource Usage approvals. Only System Admins can change
Allow Standard Users to create and assign Resources
Allow standard Users to create and assign Resources via the Resource Usage Matrix
Allow Subcontractor Users to export Resource Usages
Allow subcontractor users to export Resource Usages
Relax Work Reference constraints on Bulk Create & SYNCHRO Perform Mobile
Relaxes supervisor and actual date constraints on Bulk Create & SYNCHRO Perform Mobile to match the Resource Usage Matrix
Relax work reference constraints on Resource Usage Entry & Resource Usage Matrix
Relaxes actual date and active work reference constraints on Resource Usage Entry & Resource Usage Matrix
Show start/end times on the Resource Usage Matrix, Resource Usage Entry, and Bulk Create pages
Enables Start Time, End Time, and Break Duration columns on the Resource Usage Matrix, Resource Usage Entry, and Bulk Create pages
Show SMU Start/End on the Resource Usage Entry and Bulk Create pages
Shows options to enter Start/End SMU (Service Meter Unit) amounts Equipment Resources on the Resource Usage Entry and Bulk Create pages
Show the First Receiver column on Bulk Create
Shows the First Receiver column on Bulk Create which will set the First Receiver of a Docket when provided
Automatically create Dockets for each resource with Usage
Automatically created dockets will have a docket reference in the format of "CPY-RES-YYYYMMDD"
Require Rate Code to be specified on Resource Usages
This only applies if a Rate exists for the specified resource and date
Require a Resource Assignment for Resources on Resource Usages
This will require the Resource specified on a Resource Usage to have a Resource Assignment which covers the specified work date
Require a Resource Assignment for Resources on Attendances
This will require the Resource specified on an Attendance to have a Resource Assignment which covers the specified work date
Enable cascading of approval and locking on Invoices, Dockets, and Resource Usages
Will approve and lock associated Dockets when an Invoice is Processed. Will approve and lock associated Resource Usages when a Docket is Approved.
Enabling this setting does not cascade approve historical data. If you would like to cascade approve historical data, please contact SYNCHRO Perform Support
Notice notifications
Default Notice notification email addresses
Email addresses entered here will be automatically applied to Notice notifications
Example: “john@example.com, jane@example.com” (comma separated list)
Daily Unissued Notices Summary notification email recipients
Email addresses entered here will automatically be sent a Daily Unissued Notices Summary email
Docket notifications
Docket notification email
When a Docket changes state, send this email a notification
Send daily docket summary to each subcontractor
Send a daily notification email with a docket-state-change summary to all Subcontractor Companies containing only Dockets with at least one state change from the previous day and only with the last change if the docket's state was updated multiple times
On creation
Send docket create notification to creator
When a Docket is created via mobile, send a notification email to the Creator
Send docket create notification to first receiver
Send notification email to docket's first receiver on a newly created Docket
Send docket create notification to each person
Send notification emails to all People with a Resource Usage on a newly created Docket
Send docket create notification to subcontractor company
Send a notification email to the Subcontractor Company on a newly created Docket
On state change
When a Docket changes state, send notification emails to the Creator, the Docket's Subcontractor Company, the Project Docket notification email, and any additional recipients specified on the Docket
Send docket received notification
Send a notification when the status of the Docket changes to Received
Send docket approved notification
Send a notification when the status of the Docket changes to Approved
Send docket rejected notification
Send a notification when the status of the Docket changes to Rejected
On state change (to each person on Docket)
When a Docket changes state, send notification emails to all People with a Resource Usage on the Docket
Send docket received notification to each person
Send docket approved notification to each person
Send docket rejected notification to each person
Apply default Rate Code to Resource Usages
If the Rate for a Resource is marked as “Default”, apply the corresponding Rate Code to the Resource Usage
Add a watermark displaying location, date and time to captured images
Watermark is automatically applied to all images capture or uploaded to SYNCHRO Perform via the mobile app
Make Tags a mandatory field on the Comment/Photo screen
Forces a Tag or Tags to be selected when using the Comment/Photo screen
Enable Quantity Progress entry on the Comment/Photo screen
Allows a Quantity Progress amount to be entered for Activities that have an Earned Value Method of “quantity” via the Comment/Photo screen
Make Attendance Area a mandatory field on all Attendance screens
Forces an Attendance Area to be selected when submitting an Attendance entry
Require GPS location on Start/End/Bulk Attendance screens
Forces GPS location to be captured for Attendance entries
Show Competencies for the scanned Person on the Start/End Attendance screens
Ensure a Person's  Competencies are shown when scanning a QR for Attendance
Show Rate Code and Unit of Measure selector on the Crew Timesheet/Docket screens
If there is an applicable Rate for a Resource, the Rate Code and Unit of Measure will be shown on the Timesheet/Docket screens
Additional Docket submission for the same resource
·        Add Resource Usages to existing Dockets (duplicate Resource Usages will be unprocessable)
The uniqueness constraint of Resource Usages is applied thereby making duplicate Resource Usages unprocessable
·        Create new Dockets with distinct Resource Usages (duplicate Resource Usages will be allowed)
The uniqueness constraint of Resources Usages is avoided thereby allowing duplicate Resource Usages
Default note for Attendance start
Used as the default note when creating an Attendance start on mobile
Default note for Attendance end
Used as the default note when creating an Attendance end on mobile
Activity/Event for Attendance timesheets
The Activity/Event used for timesheet entries on the Start/End/Bulk Attendance screens
Client Resource Usage Approvals
When a Resource Usage is Submitted to the Client for Approval or Approved/Rejected by the Client, send notifications to the specified email recipients
Allow Clients to approve Resource Usages
Allow Resource Usages to be submitted to the Client for approval or rejection
Submitted to Client notification email recipients
Send a notification to the email address(es) when the Resource Usage is Submitted for Client Approval to the Client Resource Usage Approver user
Rejected by Client notification email recipients
Send a notification to the email address(es) when the Resource Usage is Rejected by the Client Resource Usage Approver user
Approved by Client notification email recipients
Send a notification to the email address(es) when the Resource Usage is Approved by the Client Resource Usage Approver user
Internal Resource Usage Approvals
When a Resource Usage is Submitted/Approved/Rejected internally, send notifications to the specified email recipients
Submitted notification email recipients
Rejected notification email recipients
Approved notification email recipients
Reporting periods
Weekly period ending day
The day of the week on which the weekly period ends on the Resource Usage Summary page
Default: Sunday
Monthly period ending day
The date or day of the month on which the monthly period ends in Analytics
Use “31” for the last day of the month
Reporting parameters
Custom project Report values
Values defined here can be included in Report and Notice Templates
Example: client_name=Important Customer Pty Ltd
Import column mappings
Column headers from external systems can be mapped to SYNCHRO Perform column headers on imports
Example: Custom Name=system_name
Report Logo
Upload report logo
Upload a company logo for use in templated reports.jpeg or.png format
