Applies To |
Product(s): |
AutoPIPE |
Version(s): |
ALL |
Area: |
Codes |
Original Author: |
Bentley Technical Support Group |
Date Logged & Current Version |
Apr. 2016 10.01.00.05 |
Problem:
What Russian codes are certified for use in AutoPIPE?
Bentley AutoPIPE includes the latest Russian SNIP 2.05.06-85 for design of above and underground Oil and Gas pipelines has successfully been certified as meeting the Russian GOST standard. AutoPIPE has also been GOST certified as compliant with the following Russian standards:
- SNIP 2.05.06-85 - Main pipelines (added in 9.4.0 in 2011)
- SNIP 2.04.12-86 - Steel pipelines of water supply and the water drain
- SP34-116-97 - Designing, construction and reconstruction oil-and-gas pipelines
- CA 03-003-07 - Technological pipelines pressure less than 10 MPa
- PTM 38.001-94 - Pipelines at pressures greater than 10 to 100 MPa
- CH 550-82 - technological pipelines from plastic
- BH 39-1.9-005-98 - Sea, coastal pipelines
- RD 10-249-98 - pipelines of steam and hot water (ASME B31.1 equivalent)
- RD 10-400-01 - pipelines of thermal networks
- RD PTM26-01-44-78 - Technological pipelines pressure more than 10 Mpa
- 32388-2013 - Process Pipes (ASME B31.3 equivalent) see note #1 at bottom of page
Certifications are available for the following AutoPIPE versions:
- CONNECT
- 10.00.00.10
- 09.06.02.06
- 09.06.01.11
- 09.06.00.19
- 09.05.01.05
- 09.05.00.21
Note:
1. Certification means that result of analyses in AutoPIPE is correspond to the GOST 32388-2013” or “our B31.3 calculations meet the requirements for 32388 and they should feel comfortable using B31.3”
SNIP Piping Code Calculation Issues
