The names and meaning of the data fields in the Telematics export files are shown below:
Field Name |
Definition |
Equipment Item |
Equipment item name |
Resource Identifier* |
An optional unique identifier of the resource, typically from another system (e.g., equipment item number, etc). |
First Seen At |
Date and time when equipment item telematic device was first seen (recorded) |
Last Seen At |
Date and time when equipment item telematic device was last seen (recorded) |
Source |
Telematic device identifier for the equipment item |
Latitude |
Last latitude of the equipment item telematic device represented as a decimal angle |
Longitude |
Last longitude of the equipment item telematic device represented as a decimal angle |
Heading (deg) |
Direction (in degrees) from the equipment item telematic device |
Speed (km/h) |
Speed (in kilometres/hour) from the equipment item telematic device |
Battery (V) |
Battery voltage from the equipment item telematic device |
