Once Usage has been submitted, it can be approved or rejected in SYNCHRO Perform, or sent to a client for their approval. Multiple Usages can also be approved or rejected at once.
Note: Only users with a Project Admin role or higher can approve Usage.
- Click on Time & Usage > People >
Approve/Reject.
- Set a date range (no greater than 62 days), then click Set Date Range.
- Click Filters to set filter as needed, then click the Filter button.
Usages can be filtered by several filters using AND or OR logic operators as needed
- Person name
- Supervisor Code
- Work Role
- Work Role Category
- Docket reference
- Tags
- Click the Group by the primary sort column option to group results into relevant categories.
- Click the boxes next to the required names, then click Approve Selected, or, click Submit Selected for Client Approval to send to a client.
The Approval Status will change from ‘Submitted’ to ‘Approved’. - Reject submissions by clicking Reject Selected.
Note: A reason for rejection must be given. - To review usage times for different Resources, click People, Equipment, or Other.
