Resource Usage Export
Resource Usages can be exported, allowing the data to be integrated into payroll systems, or other cost management systems.
  1. Click Reports > Usage.
  2. Under Resource Usages, select a Date Range, and a Project Container from the dropdown list.
  3. Click on the Work References box to select one or more Work References, or leave blank to include all references.
  4. Repeat this for the Companies box.
  5. Select an option from the Resource Usage box, or leave it blank, as needed.
  6. When all choices have been made, click Generate, then click on the Download link that appears.
  7. Use this same process for Approved Resource Usages and Resource Usages for Import as needed.
Notes:
