| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | May 2019 12.01.00.09 |
Is it possible to change Revision number for the title page on AutoPIPE's Output report?
In short, NO.
The revision number is set in the internal database. Each time an analysis is being performed in the model the revision number is incremented. This is a safety issue to be sure that multiple reports from the same model does not share the same revision number.
However, there are ways of "Resetting" that number, choose one of the following:
1. Create a new model and import the existing model into it.
OR
2. Save the model with a new filename
OR
3. Round trip the model
Output report Cover and Title page
