| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Calculation | ||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 |
How does AutoPIPE calculate the allowable for ASME NB, eq 10?
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> ASME BPV-III-1-NB (1972 - 2015)> Level A and B Service Limits> NB - Primary Plus Secondary Stress Intensity Range (Equation 10).
However, see AutoPIPE help section above for additional information about how Sm is calculated (hint: For ASME BPVC III Class 1, 2010 Edition and later...new feature was added "Use Avg Sm Allowable" check-box).
ASME BPV-III-1-NB, AutoPIPE Nuclear Piping Code FAQ
