Create a Daily Diary (Mobile)
Diary entries capture the day-to-day work of a project, recording against custom questions, such as weather, meetings, visitors, and more. Entries can be searched and viewed over time for insight into site trends.
  1. From the main interface select Diary:
    The Daily Diary displays:
  2. Define the following settings as needed:
    • Select a Date (defaults to today’s date).
    • Select Edit Answers to create a new saved answer, or select the   icon in Comment
      in each section to choose a saved answer.
    • Alternatively, select the Comment box to enter a comment directly.
    • Select the    icon on the device’s keyboard to activate voice-to-text.
  3. Choose or Capture images for each section.
    • Up to three images can be added per section.
    • Tap images to annotate.
    • A timestamp is automatically added.
  4. Add any relevant Tags to each section
  5. To save a draft, select Exit > Save and Exit.
    • View saved drafts in Drafts.
  6. Select Submit to submit the diary.
