Multiple images can be added to SYNCHRO Perform on a single Comment, which can provide additional context and information of on-site works.
- Select Comment/Photo > All Work.
- Enter an Activity/Event/Cost Code.
- Enter a Comment and add any relevant Tags.
These attach to all images by default.
- Select Choose or Capture to upload up to six images.
- Choose uploads images from the device’s storage,
- Capture uses the device’s camera to capture photos.
On Apple devices, any images stored on iCloud will not upload, and must be saved to the device before uploading to SYNCHRO Perform.
Up to 6 images can be uploaded at a time, and up to 12 images can be uploaded in total*.
- Tap on a selected image to open the image editor.
- Tap on the image to add annotations.
- Select Annotate to add shapes or text.
- Use two fingers to resize or adjust.
- Select Color to choose a color.
Different colors can be selected for different annotations. - Edit the default Comment and Tags as needed.
If the default Comment and Tags are changed, this will override any edits made here. - Select Finish to save any changes, or
to delete. - Select Edit Previous or Edit Next to navigate images.
- Selecting Edit Next with no image next in line brings up the option to add an additional photo.
- If so, select Capture Photo or Camera Roll to add additional images.
- When all images are complete, select Submit.
