Timesheet - Editing and Removing Resources (Mobile)
- To edit or remove existing resources, click Edit People or Edit Equipment on the Timesheet page.
- To remove People or Equipment from the Timesheet, click Off for the relevant slot.
- To edit default Usage Code, click Override, then make any changes as needed.
- To edit existing hours, click Override, then make any changes as needed.
- When all changes have been made, click Finish Editing, then click Next.
