Usage Codes
Usage Codes define the conditions a resource was used under. For example, if a person works a standard eight-hour day, their Usage Code is 'Normal'.  Usage Codes can be added for People, Equipment and Other Resources. Usage Codes are different from Rate Codes (the amount of money a resource costs for a certain quantity) and Work Roster Codes (the dates a person starts and ends working).
  1. Click on Settings > Project > Usage Codes​.
  2. To add a Usage Code, click on   Add Usage Code​.
  3. Enter a Name, Code and select the Resource type. Enter a Start time and End time as needed, and check the Active flag.
  4. Click either Create Usage Code or Create and Add Another as needed​.
  5. To edit an existing Usage Code, click the   icon​.
  6. To delete a Usage Code, click on the   icon​.
    If a Usage Code has a grey icon  , there are existing Usages associated with the Usage Code and it cannot be deleted.
