Rosters - Export and Import File Formats
The names and meaning of the data fields in Roster export / import file are listed below:
Field Name
Definition
Work Roster Export / Import
Supervision Roster Export / Import
Resource Name
Full name of the resource
(Format is based on Person display name format setting)
Work Date
Date the Work Code or Supervision applies from
Roster Work Code
Assigned Work Code - this must be an applicable value configured for the project
Resource Type
Type of resource (i.e., People, Equipment, Other Resource)
Resource UUID
Universally Unique Identifier for the resource
Supervisor UUID
Universally Unique Identifier for the Supervisor resource
Supervisor Name
Full name of the Supervisor resource
