Q. How to Update AutoPIPE and AutoPIPE Vessel software?
Product(s): AutoPIPE and AutoPIPE Vessel
Version(s): ALL;
Area: Install
Date Logged
& Current Version
May 2019
12.01.00.09
Problem:
Note: Only use this approach if AutoPIPE (11.01.00.23 or higher) or AutoPIPE Vessel (40.07.00.007 or higher) has already been installed.
Step 1: Open CONNECTION Client - click here
Step 2: Confirm using latest version of Connection Client, compare existing version installed with highest version mentioned in release notes here.
If needed, manually download and install latest version of Connection Client
Step 2: Check CONNECTION Client for Updates - click here
Step 3: Install updates, see video below, press on box located in lower right corner to enlarge video to full screen mode:
***Warning***
Close the applications that are now being updated and do not open them until the update has been completed. Otherwise the newly updated application may be corrupted and will need to be reinstalled from Software Downloads site.
How to download, install, and license
- AutoPIPE
- AutoPIPE Vessel
