You can capture Events, update Activities, enter Timesheets and Dockets, and record Diaries, Photos and Comments in SYNCHRO Perform Mobile while offline, with the system automatically synchronising when internet access is available.
SYNCHRO Perform Mobile automatically syncs with our server every 10 minutes when the app is open and internet access is available, however you can also manually sync your data at any time.
You can manually syncronise data or Force Sync at any time
Please note, you may need to Force Sync several times if you've been away from reliable internet access for an extended period of time.
