Download - Install - License - Release Notes- Bentley PlantFLOW
Release Notes - click here
WarningImportant:
Network drives are not supported for the software and data files. PlantFLOW software must be installed on a local client workstation.
PlantFLOW data files (*.FDA) must have full read/write access and can only be accessed from a local client workstation.Therefore, it is recommended to first copy models to a folder on local drive like C:\Bentley\ and then continue work on local copy.
  1. Download, Install, and License - PlantFLOW 06.02.xx.xx and higher
  2. Download, Install, and License - PlantFLOW 06.01.xx.xx and lower
  3. PlantFLOW 06.01.xx.xx and lower - Trouble shooting licensing
  4. What is the difference of PlantFLOW vs. PlantFLOW Plus
