| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | May 2019 12.01.00.09 |
Nothing appears to happen when pressing "Scan sub-directory for models" button in AutoPIPE's Batch generator, why?
The button has 2 states, On and Off.
Pressed ON = (Blue outline shown)
Pressed OFF = (No Blue outline)
By default the button is pressed OFF.
In order to search sub-directories, first press "Scan sub-directory for models" button to ON , and then press "Add directories for Batch Processing" command
to search sub-directories for AutoPIPE models.
Otherwise, if "Scan sub-directory for models" is OFF , no sub-directories will be scanned for AutoPIPE models when pressing "Add directories for Batch Processing" command
Trouble Shooting Batch Processing
