| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Processing | ||
| Date Logged & Current Version | Apr. 2016 10.01.00.05 |
How to avoid Error and Warning dialogs from appearing when processing an Batch Processing / Automated Processing in AutoPIPE?
On AutoPIPE Batch Generator dialog, look under the Options List and enable the following option:
- "Suppress GUI"
and / or
- "Suppress Warning Messages"
Note: Before adding a model into a batch process script, best to open that model and confirm any potential problems, Suggest to set the input / output reports options as needed for that specific model as the Batch Generator cannot make changes to these types of dialog. This also goes for all Analysis sets, Analysis set options, Dynamic loads, error messages, etc..
Trouble Shooting Batch Processing
