| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Processing | ||
| Date Logged & Current Version | Apr. 2016 10.01.00.05 |
What are the common mistakes made that would prevent an AutoPIPE Batch Processing / Automated Processing to not work?
See a list of possible solutions:
1. Licensing:
Check to be sure that the command switches that are being used can actually be used in the AutoPIPE edition selected before running the batch.
Check to be sure that the actual license is still valid, see wiki here for interactive guide
2. Wrong syntax used on the command line.
Check to be sure that the syntax is correct, Try performing a simple batch as shown here to perfect syntax before processing a whole batch of models.
3. AutoPIPE.exe is not in the current folder where the batch files are located.
See simple batch WIKI here, step #6.
4. Try to manually perform the same steps in the Batch with one file to be sure that all the steps can be completed in AutoPIPE without issue, before automating it.
Trouble Shooting Batch Processing
