| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Licensing |
| Date Logged & Current Version  | April. 2017 11.00.00.22  |
What happens with respect to licensing when a non-trust license version of the program, AutoPIPE XM 08.09-xx.xx to AutoPIPE V8i 09.06.02.xx, is opened by a user?
Let us make some assumptions clear:
1. User is able to press Test connection button in LMT (License Management Tool) and following appears:
SELECTserver and Activation Key verified.
2. No Bentley licenses are currently checked out.
3. User has not started AutoPIPE in over 3 days.
User Starts AutoPIPE by selecting Icon on desktop or using Program listing hyperlink
AutoPIPE starts by displaying a splash screen
At this point, the program will try and license the last edition of the program (ex. Standard, Plus, Advance, or Nuclear),
For this demonstration assume that AutoPIPE Plus License Request was sent AutoPIPE and passes through the Bentley IEG security layer.
a. If AutoPIPE does NOT find Bentley IEG installed, program reverts to Demo mode
b. If AutoPIPE does find Bentley IEG installed, go to Step #3.
The AutoPIPE Plus License request passes through Bentley IEG and is sent to LMT.
LMT looks at the License request and then compares the request against the list of products on the License Checkout tab.
Is AutoPIPE PLUS listed?
a. NO - dialog appears, No License found for AutoPIPE PLUS, Converting to DEMO.
b. Yes - goto Step #4:
Note, at this point all trust license applications, i.e. AutoPIPE V8i 09.06.03 and higher, will not prevent a user from using the application nor will it check out a license. LMT would send an "AutoPIPE Plus License Request granted" signal back and the user can accomplish their work. At the end of the month program usage, number/type of licenses in use, would be compare against the contract. IF usage exceeds contract agreements, an invoice is sent out for that amount of overusage. If usage does not exceed contract agreement, no invoice is generated.
It is a benefit for the user to be able to get their work done with the application and features required and only having to pay a portion of a full license actually used. Account salespeople can always help modify a contract agreement to ensure the correct balance of licenses exist on a contract to help keep costs down. Paying for only what is needed.
LMT checks to see the number of licenses currently available. Are there 1 or more Licenses available?
b. Yes - goto Step #5:
LMT Automatically checks out a license for 2 days against the user currently logged in (this is hard-coded in the licensing component). A new entry is made in the lower window on the License Checkout tab. This new entry tells the program
LMT sends a signal to the SELECTServer updating the pool / usage count. Goto Step #7.
LMT sends an "AutoPIPE Plus License Request granted" signal back to BENTLEY IEG, Then from IEG the signal is received by AutoPIPE.
Was License request granted?
b. Yes - the user is able to start using AutoPIPE Plus. Go to Step #8.
A. User closes AutoPIPE before check out time expires.
An "AutoPIPE Plus License is no longer being used, check-in" signal is sent from AutoPIPE, back through Bentley IEG, to LMT. LMT looks at the signal and verifies, "Yes, this is a valid AutoPIPE Plus License signal, proceed to check-in".
LMT automatically checks the license back in
a. The check out entry in the bottom window on the License Checkout tab is removed.
b. The number of Available license next tot the respective product in the upper window on the License Checkout tab is increased by 1.
c. SELECTServer is updated with pool / usage count. Goto Step #9.
B. User does not close AutoPIPE before check out time expires.
once the expire checkout data is reached , without warning to the user, AutoPIPE will automatically reverts back to demo mode, and at the same time LMT automatically performs all 3 steps mentioned above.
a. All customers who sign up for Select had this sent to them: Term License Fact Sheet
b. Confirm whether your product benefits from the 10-minute usage interval
c. How to Take Advantage of Bentley's Allowance for Usage Under 10 Minutes (Product List)
d. Non-pooled, Passport License Usage and How is it Calculated
While SELECTserver cannot restrict usage, as noted in answer to the first question in the License Behavior FAQ, there are several ways in which you can manage and reduce your license usage.
Currently SELECTserver looks at usage based on a each hour of the day. To avoid overusage in the same hour best for 1st user to close AutoPIPE in order to check license back in and for 2nd user to wait an hour before starting the program. Again, this was all mentioned in the SELECTserver agreement that has been sent and agreed too by all users who signed it. .
The video demonstrates before starting AutoPIPE XM 08.09..xx.xx that no license are currently checked out in LMT.
Once AutoPIPE has been started and LMT refreshes, a license has been automatically checked out but will expire with in 2 days of the current date.
Note: Products that utilize the Bentley IEG License Service (i.e. RAM, STAAD, AutoPIPE, SACS, and FormSys products) will check out licenses for a duration of two days. This is hard-coded in the licensing component.
After AutoPIPE is closed and LMT refreshes, notice that the checked out license has been automatically checked back in.
