| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Results |
| Date Logged & Current Version | April 2019 12.00.00.14 |
Why is there no Max Range code combination for HDPE piping with the "Include Max Range comb" option enabled?
At this time, May 2019, Max range code combination only applies to metallic piping and not default combinations with the suffix "-HDPE".
Create a user defined combination to find maximum resultant moment among all the default combinations with the suffix "-HDPE".
Example:
Model has 3 temperature cases, create a user defined combination. Suggest that Combination method be set to 8-Res Max and Category be set to PE Expan, and then add up to 10 default load combinations to be evaluated.
Note: if a model has 50 thermal load cases to be evaluated, suggest to create 5 new user load cases to evaluate 10 load cases each, and then create an additional load case to evaluate the 5 new user load cases. Thus finding the load case with the highest result quantity based on resultant maximum at each location.
"Include Max Range comb" setting
