| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Library |
| Date Logged & Current Version | April 2019 12.00.00.14 |
The following appears when importing / opening a model in AutoPIPE:
Note
N144-26: B31.3 and B31.1 material libraries can be updated with instructions given in the Online help Reference Information.
For all other libraries please contact Bentley Technical Support
OK
why and how to avoid it?
As indicated in the message, see the following AutoPIPE help section:
Help ribbon> Contents button> Contents Tab> Reference Information> Libraries > Libraries document, See also " Adding Materials to the Flange Check Material Library "
In addition, for more information see WIKI page here.
