| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | License | ||
| Date Logged & Current Version | June. 2016 40.01.00.08 | ||
How to check that my license is reporting correctly for an AutoPIPE product?
LMT (License Management Tool) has a checking of usage of all product IDs. Therefore to see if usage is being reported by the application perform the following:
Example: Using AutoPIPE Vessel v.40.01.02.01
Note: Product ID 2250 = Vessel, where Product ID 2251 = Vessel Enterprise.
If a usage for Product ID = 2251 is recorded, this means that AutoPIPE Vessel Enterprise is reporting usage correctly. The Select Server information is updated automatically at the end of the day or the information can be sent now by pressing keyboard key F9 (send logs now). After the light show has finished, the Select Server will no be updated with the usage reports.
