| Version(s): | ALL |
| Area: | License |
| Date Logged & Current Version | July 2018 40.06.00.07 |
What are the difference between Vessel and Vessel Enterprise SELECTserver XM licensing?
The following table lists features that are available when selecting either Vessel or Vessel Enterprise license for SELECTserver versions 40.xx.xx.xxx and lower
Notes:
1. Again, only those features with a check mark next to them will be available with the indicated license type selected.
2. Vessel license are entitled to only 1 Add-on code to be available when using the program (user to specify). Additional Add-codes can be included, contact your Bentley salesperson for details and pricing. For ELS accounts only, these accounts will be reset / invoiced on their renewal dates for any usage of Add-on codes.
License Configuration - What do you see
