| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | analysis | ||
| Date Logged & Current Version | May 2015 09.06.02.06 |
How to assign code allowable stress for hydrotest loading: hoop stress and HY stress combination in AutoPIPE?
After creating the respective analysis sets, run a Static analysis, and open the Load Combinations dialog, as shown below:
Currently all the combinations have a code allowable that calculated Automatically. However, a user defined value can be specified by
Step #1: Unchecking the respective boxes in the Auto Update column,
Step #2: Changing the Allowable (k) factor and / or Allowable Stress column values as needed.
Press OK button to close the dialog and create an out put to review the results.
