| Product(s): | AutoPIPE Nozzle | ||
| Version(s): | V8i | ||
| Area: | Warning | ||
| Date Logged & Current Version | May. 2016 10.01.00.09 |
The following message appears when using selecting a material
Warning
Missing material library file
OK
Why and how to avoid it?
Open AutoPIPE Nozzle's program folder:
C:\Program Files (x86)\Bentley\AutoPIPE Nozzle V8i
Confirm that ASME2.bin file is located in the folder?
This file was missing from AutoPIPE Nozzle AutoPIPE 08.11.08.23 & 08.11.08.26 which were installed with AutoPIPE V8i 09.06.01.10 to AutopIPE CONNECT 10.01.00.09.
There are 2 methods to resolve this issue:
1. Request Library file from technical support
Submit a Bentley Service request referencing this WIKI and asking for this missing library file.
After receiving the file, copy it to the AutoPIPE Nozzle folder:
And, restart the program.
2. Upgrade
Upgrade your version of AutoPIPE to install a newer version of AutoPIPE Nozzle that does not have this issue.
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE Nozzle
