02. Elbow / Bend Pipe Supports Modeling Examples in AutoPIPE
AutoPIPE online help has the following 5 elbow support example systems available for review, Inside of AutoPIPE select:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches> Bends> Base Supported Elbow>
Note: see each support example and related questions below
Model 1: Supported at a tangent point
no questions on have been submitted for this support example
Model 2: Supported at a point along the bend
Model 3: Alternate method for defining a support at a midpoint
Model 4: Modeling a "dummy leg" as a structural member
Model 5: Modeling a "dummy leg" as a pipe
Available AutoPIPE Help Example Methods for Modeling Supports
