04. Beam / Frame Structure and Supports Modeling Examples in AutoPIPE
Frame structures are commonly used to support piping systems. In most cases, the structure is assumed to be much stiffer than the piping itself and can be modeled simply as a rigid support. However, AutoPIPE also allows a supporting frame structure, such as a pipe rack, to be included in the system model.
AutoPIPE online help has the following 3 Pipe Rack example systems available for review, Inside of AutoPIPE select:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches> Frames>
Note: see each support example and related questions below
Pipe Rack (Method 1)
no questions on have been submitted for this support example
Pipe Rack (Method 2)
Pipe Rack (Method 3)
Available AutoPIPE Help Example Methods for Modeling Supports
